Change DFS mode
Hi all.
I have a working P2P link when DFS mode is set to “none”.
As soon as I change it to “radar detect” or “no radar detect” wds client cannot connect anymore.
When I change back to “none” it connects.
Do I need something else to change that DFS mode works?
I can post configuration.
One side is Mode: bridge
Other side is Mode: station wds
latest version: v6.30.2
Click on thumbnail for larger picture::
I’ve found in manual: http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless
dfs-mode (no-radar-detect | none | radar-detec; Default: none)
Controls DFS (Dynamic Frequency Selection).
  • none - disables DFS.
  • no-radar-detect - Select channel from scan-list with the lowest number of detected networks. In ‘wds-slave’ mode this setting has no effect.
  • radar-detect - Select channel with the lowest number of detected networks and use it if no radar is detected on it for 60 seconds. Otherwise, select different channel. This setting may be required by the country regulations.
This property has effect only in AP mode.
So if “This property has effect only in AP mode” then I cannot set SXT with Licence level3 into AP mode therefore can’t use radar detect for SXT?
