the internal storage of the router is completely full and I’m hoping for the possibility of changing directory location of the folder UM5Files to be stored in another storage. Thank you
Hmmmm not documented in the CLI, it is not in the F1/Help list, not in the export, not in the export verbose … It is in the webfig and Winbox
By analogy to the older Usermanager it should be the same, but without the /tool, as in http://forum.mikrotik.com/t/failure-bad-path-when-moving-usermanager-database-to-usb/143242/1
Thanks but that’s the database path, I meant the html files for User-Manager under the directory: um5files
No idea, those are small compared to the DB. The database is moved to Disk1.
It looks like the um5files are in memory, not in the Flash, if they are in in Flash I expect Flash/um5files/PRIVATE as directories etc etc
