Change from gateway 1 to gateway 2 after X amount of bandwidth usage?
currently on my system I have 2 gateways, one 10Mbit with no limit and one 60Mbit with 75GB limit, I want to know if it is possible to get to change from the gateway with 75 GB limit after daily amount of traffic has been used up by all of the users on the network? And to reset back to it next day? So, basically I have one ISP on interface 1 and the other on interface 2, what would the easiest way be to just disable interface 1 after X amount of daily traffic has been used up? It will automatically switch to interface 2 because it has been set up like this.
Thnx
