Change from StarOS to Mikrotik
We currently use StarOS WAR1a boards for remote BH’s on towers where we only expect to have 15 to 20 clients. We have been experiencing problems with the WAR1a’s and would like to switch over to MT’s. Any suggestions as to which MT routerboard we should consider using? We normally BH with 5GHz, using XR5 radios. Link distance is usually under 10 miles. Thank you for your help.
