change gateway for some URL
dear friend
i have 4 internet line and i’m using load balancing for 3 of them
i need to change some configuration for separating some URL
for example i need change the way for http://google.com http://routerboard.com http://mikrotik.com
i want when some body need this url excactly work with ether5
here you can find my configuration
/ ip address
add address=192.168.100.1/24 network=192.168.100.0 broadcast=192.168.100.255 interface=ether1 comment="" disabled=no
/ ip dhcp-client
add interface=ether2 add-default-route=yes use-peer-dns=yes use-peer-ntp=yes comment="" disabled=no
add interface=ether3 add-default-route=yes use-peer-dns=yes use-peer-ntp=yes comment="" disabled=no
add interface=ether4 add-default-route=yes use-peer-dns=yes use-peer-ntp=yes comment="" disabled=no
/ ip firewall nat
add chain=srcnat src-address=192.168.100.0/24 action=masquerade comment="" disabled=no
/ ip firewall mangle
add chain=prerouting src-address=192.168.100.0/24 action=mark-routing new-routing-mark=SUBNET-LAN passthrough=yes comment="" disabled=no
/ ip route
add dst-address=0.0.0.0/0 gateway=X.X.224.1,X.X.128.1,X.X.160.1 check-gateway=arp scope=255 target-scope=10 routing-mark=SUBNET-LAN comment="" disabled=no
Add mark-routing rules for the specific DST-address of MikroTik/RouterBOARD/google and use mark-routing in /ip route configuration.
dear sergejs
could you please give me one example or command?
up!
[admin@testbox] > /ip firewall address-list add list=route-differently address=6.6.6.6/32
[admin@testbox] > /ip firewall address-list add list=route-differently address=7.7.7.7/32
[admin@testbox] > /ip firewall mangle add chain=prerouting action=mark-routing new-routing-mark=my_routing_mark dst-address-list=route-differently
[admin@testbox] > /ip route add gateway=1.1.1.1 routing-mark=my_routing_mark
HTH,
Felix
thank you so much dear felix
I’ll check it tomorrow.
can i have your contact information?
