recently i installed routerOs on pc with license level 3 but i want to change the mikrotik for some reason
to another one with same license is it possible ???
Contact support directly for license questions.
you can move your HDD with RouterOS to any PC you want - license should not change
is that work ??? are you sure ???
sure. SoftwareID is based on HDD parameters only
