1.How to change language ?
2.If I will install new ver6.11, my settings in router will be saved ?
on router
RouterOS only works in English, but if you use Webfig, you can use “Design Skin” button to translate the menus.
mcmerphy:
normis:
- language where?
- yes, if you upgrade, not reinstall.
on router
Really ?
How to install new packages ?
Really ?
http://wiki.mikrotik.com/wiki/User_Manager/Languages
User manager is not RouterOS. It is a RADIUS server for user management.
mcmerphy:
Really ?
http://wiki.mikrotik.com/wiki/User_Manager/LanguagesUser manager is not RouterOS. It is a RADIUS server for user management.
Thank you. How to install Webfig ?
Webfig is installed by default. Open the router IP address in your web browser.
I did it, but interface is still in english, how to do it russian ?
normis:
You will need to find somebody to create a translation. Click ‘Design Skin’ and start changing names to Russian. We have not made a Russian Skin, so you can be the first.
Thanks.
I cant understand what the difference between forward and outgoing in firewall rules ?
Thanks.
“forward” means “traffic going from one network to other, throguh the router”
“output” means “traffic coming from the router itself”
“input” means “traffic destined to the router itself”
mcmerphy:
Thanks.
Ok, if I want to connect to my router using ftp, I have to choose input, source ip 0.0.0.0(any ip), and destination ip, what ip in destination ?
You want to allow FTP connection to router, and block others?
Make input rule with action “allow” and the needed ports, and protocol “tcp”. IP leave any.
any means 0.0.0.0 ?
Forward means traffic goes from one local network to another local ?
Ok thank you.
If I want block http trafic from local to internet what I have to use ?
forward or output ?
if “local” is local users, then you have to use forward.
