Hi folks,
How can I change the color of the LED, especially the red blinking Wi-Fi signal LED?
hAP (RB962UiGS-5HacT2HnT)
Hi folks,
They are fixed. You could dismantle the Mikrotik, unsolder the LEDs and replace them with different ones but that is a rather excessive solution.
You can disable all/most LEDs or change the function of some LEDs depending on model, see https://help.mikrotik.com/docs/display/ROS/LEDs. Otherwise you can stick tape over them to block or reduce the brightness.
