Good morning, I have several vlans in my mikrotik, and inside each vlan I have a DHCP! How do I change the network name in each vlan to appear over the network card model in windows! As in the picture:
Hey. I believe this SSID name. And it can be changed in a router settings in WiFi section.
The SSID is for wireless network, not for cable network
Would make sense if it was a WiFi adapter.
As far as I know it is a workgroup name (configured on the server).
You’ll need to do so in the Registry.
Some networks the name is automatic.
Oh, true. Sorry
You can try to do this here in regedit:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles\ProfileName
Perhaps you can use DHCP ( IP DHCP Server Networks) and set the Domain option (for AD-Domains) or set a WINS-Server.
What was the solutions to it
Just read the previous posts.
