Change network
Good morning, we have a MikroTik RBwAPG-60ad Kit. I’ve want to chage the default network from 192.168.88.2 or 88.3 to 192.168.0.110 and 192.168.0.111 these ip address are free in our network. I have try to do it several times with no results, the wifi bridge stop to response and i need to restart it to factory defaults again. How can do it? I’ve want to have the Mikrotik in the same management network.
Thank you for your help.
Hello, you need to brigde all the ports in order to make it work.(or at lease the uplink)
I would suggest to add new addresses first, then remove the old ones.
I tried that, could not remove the old ones. under WebFig > IP > Addresses
Of all the videos on the web, NO ONE has been able to change the IP address, they are all showing 192.168.88.xx
Perhaps a more detailed explanation would benefit many people. After watching every youtube video, no one has been able to change it from 192.168.88.xx
I tried what you suggested by going to IP > Addresses > add 192.168.19.53, Eth1, then rebooted and removed 192.168.88.2, changed to .19 on computer and could not log on.
Multible trys, only re-setting to default worked, and that does not help me use these systems.
Use Winbox
Connect your computer directly to the Mikrotik
Set a static IP on your computer of 192.168.88.88
Open winbox and select Neighbors
The Tik should show up via IP and MAC address.
CIick on the MAC address and it will populate in winbox
Hit connect
Navigate to /IP address
Select the IP address and change it whatever IP you need.
NOW SINCE YOU ARE CONNECTED VIA MAC ADDRESS, YOU SHOULD NOT GET DISCONNECTED.
Repeater with the other side.
Point then at each other.
Connect one side to a working network
Connect your computer to the other Tik.
Set your computer back to DHCP
You should get an address from your network, assuming the 2 sides linked.
