Hi
How to change the defaults dns provided per the dhcp-client and it replace /override/force it by 8.8.8.(ie)?
I have a lot of difficulties to find the answers on forum and help.
Thanks a lot
[admin@MikroTik] /ip dhcp-client> print detail
0 ;;; default configuration
interface=sfp1-gateway add-default-route=yes use-peer-dns=yes
use-peer-ntp=yes dhcp-options=hostname,clientid status=searching...
1 ;;; default configuration
interface=ether1-gateway add-default-route=yes use-peer-dns=yes
use-peer-ntp=yes dhcp-options=hostname,clientid status=bound
address=85.27.7.52/24 gateway=85.27.7.1 dhcp-server=85.27.7.1
primary-dns=109.88.203.3 secondary-dns=62.197.111.140
expires-after=6h43m10s
[admin@MikroTik] /ip dns> print
servers: 8.8.8.8,8.8.4.4
dynamic-servers: 109.88.203.3,62.197.111.140
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 323KiB
