Change platform value
Is it possible to change or remove the platform value (platform=“Mikrotik”) in a simple way ?
Best Regards
Do you mean the device name?
You can set that under system > identity
Best regards
I’m interested to remove or change the platform value and not the identity.
To see the platform value, run NeighborViewer.exe or digit : ip neighbor , print detail
Best Regards
You can’t.
If you don’t want your router to be seen disable - disable neighbor discovery
mrz :
I can’t, but someone else can do it. I buyed many mikrotik routers from different companies with platform value changed, I need if it possible to remove or
change it.
Best Regards
This is called branding. You can contact support for more information.
