I got a pppoe client myname1 with two profiles.
I want to run a script that changes the client’s profile from for example a day profile to a night profile and vice versa.
I already got a script from Chupaka which removes the active client and then he willl connect using the new profile..
It is always nice to see someone actually answering the question and only the question.and not go way-wire with other crap.
Very professional. Thanks !
Professionalism is when someone tries to give you a correct advice and not just an answer that might get you in more trouble with your configuration…
Obviously you dont care about that, you just want the job done, you dont care if there is a better way, you are bored to explain your problem, to give all the details, what is the use of the PPPoE client and a lot more…
If you dont care to explain i dont care to answer you back.. as simple as that.. Have a nice day…!
