I would like to change my outgoing public IP for a public IP range, in the sense that the source IP will always be the same, but for each new access session through the Browser with the same destination destination, the public IP specified in the range would be changed
currently with the rule below applied when accessing the specific site, the outgoing nat rule works with the public IP specified in the outgoing range, but when closing the browser and opening it again with access to the same destination, the nat always keeps the same public ip output, I would like that at each access, connection session, nat alternates the public IP
follow the current rule
dd action=src-nat chain=srcnat comment=
“Internet Outgoing IP 172.30.6.10 Siscom web” out-interface=
ether5 src-address=172.30.2.7 to-addresses=
200.222.2.198-200.222.10
It is possible to carry out this configuration for each new session of the browser always using the same destination, changing the outgoing public IP, as this is not happening. it only changes the public IP when accessing different destination sites
