Hello!
I have setup with 2 WAN. I have problem with changing default route “on the fly”, because changing route keeps connections(/ip firewall connection) in old state. So, to accomplish switching i have to manually flush old connections. Is there some hint to fix this?
not really, unless you have your own IP address range with your own AS. Then you can route your packets as you wish.
