Change script owner
Hallo,
is there any comfort way to change script owner (eg. from “admin” to “john”)? The reason is that for security reasons the “admin” user was deleted and user “john” was used instead. Now, some scripts have the old user’s name and some the new name, but I want all to share the same variable space…
Thank you all for the hints.
I have found it: It is enough to open the script by the new user, fictively change it forth and back and press “OK” button.
The owner is then changed.
a cli command would be assume
