Change SNMP Port on RouterOS v6.22
Is it possible? I have device behind MT and only one public address and would like to manage them both with Dude.
In NAT on the router terminating the public IP, simply NAT the requests correctly:
PublicIP:SomePort → LocalIP:161
/ip firewall nat add chain=dst-nat dst-address=publicip proto=udp dst-port=someport action=dst-nat to-address=localip to-port=161
Ah, yes, of course!
Thank you!
It doesn’t work for me until I added another rule that allows udp traffic to publicip on port 161
In this case I have two opened ports: “someport” and 161.
snmpwalk -c public -v 2c publicip:someport
works fine! Good!
but
snmpwalk -c public -v 2c publicip:161
works too, and it’s not what i want
How i can get router to listen for snmp requests ONLY on “someport” ?
