Hello ,
Is there any way I can change my routers ntp server using the dude?
I have many routers I need to change (approximately ~250) ,and I don’t want to this one by one
Thanks ,
Hello ,
Thanks ,
Maybe this will help: http://forum.mikrotik.com/t/send-remote-commands/41289/5
it’s half way there
but it’s doesn’t say how to do this - only what need to do
maybe there is another explain?
thanks ,
Well, using ros_command() is probably not the best option. I don’t think there is a way in Dude to do a “one click” mass configuration change.
This software looks promising. http://www.routertools.com.au/
