change source port of incoming packets
Is it possible to change source port of an incoming packet to the router before the packet reaches its’ destination (destination is directly connected to the router)?
I have a client connected to my router which accept packets just with source port of 1720 (it has no restriction on destination port)!
My incoming packets have source port of 1270 so I must change source port of the incoming packet to 1720 (packet is coming from a network not directly connected to the router) before forwarding it to my client.
All suggestions are welcomed.
Use the SRC-NAT action to do so. I’m not sure what your goal is however, that sounds like it will likely create a broken connection since the source IP won’t know to listen to that port for reply packets since it didn’t start the connection with that src-port.
I am trying to bypass an ISP which blocks packets with srcport and dstport 1720.
A packet comes from 1.1.1.1:1111 (from the Internet and by source port 1111) and goes to 2.2.2.2:2222 which is directly connected to the router.
I add a srcnat rule then I can change source port of the incoming packet (1111) to e.g. 5555, correct?
chain=srcnat action=src-nat to-addresses=1.1.1.1 to-ports=5555 protocol=tcp src-address=1.1.1.1 src-port=1111
Basically yes. The router at the other end needs to know to change it back so it doesn’t make for a broken connection.
