Then you are using the local database on the router. You will probably need to use a script to do what you want. I would try changing the user’s group (profile) and logging them off (or change the dynamic simple queue setting?) when they exceed the maximum totals. When they log in again, they will get the lower bandwidth. Then at a specific time each day, change them back to the original group (profile).
