I’ve followed the guide
http://networkingforintegrators.com/2012/11/mikrotik-how-to-change-the-dhcp-range/
but the problem is that I can translate to an adress, but I cannot ping…
I also can’t surf. How can I fix this?
Pirlet
You can try to verify your settings with Quickset
Post your export.
Make sure you are adding the subnet mask on the end. I did this setting something up recently and it stumped me.
**192.168.1.1/24
***not 192.168.1.1
