change the port of a source IP for monitoring AP behind NAT
I am trying to monitor some AP’s that are NAT’d for my Zabbix system, I would like to setup a mangle rule to strip the snmp port on that source IP and excahnge it for a sequential port for the 10 access points needing to be monitored. for example port 40001…40002…etc. for each AP.
Can this be done and if not is there a better way to do this please.
Thanks.
when adding clients stations behind the router in your SMTP server configure
  1. router ip, listen on XXXX
  2. router ip, listen on YYYY
and on the router redirect the ports
I dont know, it may work for you
huh. :confused:
