The network link was interrupted while negotiating a connection. Please try again.
I replace my routerOS gateway with a Linux IPtables gateway and get the same error. But checking some options I found with this command that I run in my linux box.
it doesn’t work for me as well, so that’s a problem with the website. i doubt that all their visitors install Linux and modify their Kernel just to browse one page
The tcp-window-size that you are setting with the mentioned command is directly linked to the amount of RAM. So, you could simply put more RAM into the machine to solve this issue (more RAM will increase TCP window size). This affects only the Webproxy in RouterOS, and from the description of the issue, looks like tcp-windows size is not the only problem, could be some configuration issue or undiscovered RouterOS proxy problem. Hard to say. But - disabling webproxy will also solve the issue.
sorry to say that, but it’s definitely proxy problem: when I enable proxy on one of my routers (it’s x86 v4.2), I can browse any website except http://www.pacificard.com.ec/ %)
maybe GZIP encoding of webpage is the reason? can WebProxy work with compressed data?..
p.s. actually, after a minute or two, webpage opened… after refresh, it shown
<!DOCTYPE html PUBLIC "-
and stopped. one more page reload - four minutes, no reaction… when I disable proxy - I can browase the website smoothly
I understand that this is caused by the proxy, but why only one website? I have not seen this behavior with any other website, and I use proxy for a very long time.
for example, look at ticket 2010101966000509 (it’s not my one, but I was commenting it to Sergejs) - was it solved? that webserver has one insignificant difference in its header part - and WebProxy cannot process it correctly
