hi
Change the way Mac Idriss ethers Almaekerotk 1100 Whenever I tried a lot but does not change because the Mac is invisible and thank you
After decrypting your question I presume you’re asking “how do I change the MAC address of an interface on a RB1100” ![]()
/interface ethernet set ether5 mac-address=00:00:5E:80:00:1D-Chris
When you go to them they are invisible even to change much and what I do the way
Do it from terminal, it works perfectly.
-Chris
thankes
