Hi, I need to change some property of the wireless interface on CAP which is controlled by CAPsMAN. For example, hw-retries, wireless protocol, datarate…properties that are not available to configure through CAPsMAN.
I can disable CAP protocol on CAP router, change the necessary property values and then enable CAP protocol. Should these changes be applied or not…?
