ChangeIP
Anyone else have any luck with their ChangeIP scripts since the website changeover?
what is that mean?
I’ve got problems too. Script reports Authentication Failure
Same problem here.
ChangeIP is a Dynamic DNS provider. There is a script available herewhich allows us to update our DNS via RouterOS.
However, at the end of September, ChangeIP did a massive upgrade of their systems, and it appears to have broken the script.
Log reports “Authentication Failure”, but I know that my username and password are correct (I can log in on their frontend with these credentials).
I’ve got problems too. :confused:
The script reports “Authentication Failure”, however on the website (changeip.com) I can logon using the same credentials.
Reply on a ticket I submitted.
We have identified a problem that is affecting use of updates via devices and scripts. A fix is being implemented and should be in place within the next 24 hours. In the meantime, manual updates via DNS Manager are working. Thank you for your patience.
I opened a ticket on “changeip.com” and they told me the following
We have identified a problem that is affecting use of updates via devices and scripts. A fix is being implemented and should be in place within the next 24 hours. Thank you for your patience.
Thank you,
ChangeIP Support
Same problem here “Authentication Failure”
using “homing Beacon” script
me too.
any updates for the script guys? my previous site that using the changeip script got no problem, still can be use for remote but there’s an error msg on log ----> http://i.imgur.com/bWnUyHF.png. But apparently, we will got a problem to setup the script on a new site.
any update i m also facing similar issue
already solved.
it works again!
thanks
thanks
again authentication failure error
I just reset my ChangeIP password now and it started working again. My details weren’t working for the site anymore either though.
yes you are right
and one thing is that my change ip password not works then i reset my password
and script working now
thanks
