Can someone post the changes here… The website is busy with people downloading again and this usually last a day or two. Also, if osmeone would not mind placing links to:
2.9.49 RB500 / x86 & 3.0rc10 RB500 / RB333 / x86
That would be outstanding. I could use a web stress test myself but I can’t get the files
*) fixed problem - sometimes PPTP, L2TP, PPPoE and OpenVPN connections
were not accounted properly, and no new connections could be established;
*) fixed problem - L2TP sometimes could not establish connections through
firewall or with Windows;
*) bgp - fixed TCP MD5 authentication on RB300;
*) fixed bug - route did not work with Level 1 license and routing package enabled;
*) api - ‘/quit’ command now immediately terminates session;
*) console:
‘and’ operator in expressions that follow ‘find’ and ‘print where’
now is optional, pre-rc9 syntax ‘find mtu=1480 type=ether’ works
as it used to;
added back filters to firewall print commands, filtering by chain
now is ‘print chain=input’ instead of ‘print input’;
fixed ‘print count-only’, it was ignoring any additional ‘print’ arguments
that selected only part of items;
What’s new in 2.9.49:
*) nand improvement for RB532A;
*) user manager - fixed bug with accounting creating too many sessions;
I’m downloading all of the files right now. I’ll upload them to my mirror when I’m done.
