I am currently using a RB512 with a CM9 as a 5Ghz Station. But for some reason, after I changed the Band to “5GHz” under the wireless settings, the status tab still says “Band: 2.4Ghz”. I discovered this after I could not get this one client in a PTMP to associate to the RB512/CM9 AP-Bridge in the 5.8Ghz. I have rebooted the unit, and also tried to kick-starting it by changing the Band a few times, but I had no luck.
I was having this problem with rc8, so I upgraded it to rc10, but I still have the same problem. Any thoughts? I don’t have another CM9 handy to swap it out, but is it possible that there is something wrong with it instead of MT? Please note that when I run Freq. Usage, it does appear to see the 5Ghz frequency from the AP.
