Changing def. columns in winbox wireless registration table?
is there a way to change default winbox appearance in wireless registration table? I need a command to display, for example, Rx/Tx CCQ, Tx Signal Strenght columns and not to display “Last Activity (s)” column.
I know it is possible to change it from winbox itself (show columns) but due to high number of routers it would be extremely time consuming to do it that way (a technician to login manualy via winbox on each router and do enable/disable specific columns by clicking on it by mouse :slight_smile: ).
So, I’m looking for a console/terminal text command(s) to change this fast and permanently.
Thanks.
Why don’t try Webfig. Just customize the skin and save it. then in files you can see that. just copy and past it to all Routers and use that skin.
