Changing frequency
Hi, if I have an AP with various sxt client connected can I change the frequency on the AP without change that on the aps client?
If I do this in the wireless tab of the client the frequency is always the old but the ap will connect correctly on the new frequency.
The clients scan all frequencies based on their regulatory-domain and connect to the AP even if you change the frequency. So you can safely change the frequency on the AP and if both AP and all clients have same country selected they will reconnect.
Thanks. But why on the client there is alway the old frequecy on the freq field?
Think of it like this :
The stations will use auto as frequency and this parameter is used on ap-bridge or bridge. This frequency will be used if you switch that interface to ap.
