Changing mac address on wlan
Hi there, can somebody tell me if I can change the mac address of a wlan card in Mikrotik or an ethernet cards mac address, I need to know if this is possible :unamused:
Yes
/Henrik
Yes and No.
You can’t change ethernet mac as far as I know. If somebody figured out how, let me know. But you definitely can for wlans.
Yes, you can change for wireless too.
in β€œ/interface ethernet set ether1” you can set the mac address of ethernet interfaces.
That is good to know.
Can you add multiple mac adresses to the same ethernet port?
it`s working, thnx :wink:
ccr, no you cannot.
will this be possible in the future ? I kind of need it for
http://forum.mikrotik.com/t/multiple-public-ip-s-on-mt-wan/11079/1
