changing my ether PoE-in port from 1 to 5 in mikrotik RB951Ui 2HnD using winbox
please pals i am new to to mikrotik and i have an RB91uI 2HnD , which am using, the port 1 is bad , please how do i change the wan port from 1 to 5 so it can give internet automatically and secondly please how do i configure the router from scratch so that i can connect to my isp , all using winbox..please a step by step approach wil be very appreciated, waiting for your response as soon as possible please.
thanks…
  1. Remove ether 5 from bridge if it was in.
  2. Replicate all settings of port 1 to port 5.
  3. Remove all settings of port 1 from the configuration.
  4. Check and correct all routes, port lists, firewall rules and other stuff whether it is correct, eventually correct it manually accordingly to your change.
  5. Plug the wire from port 1 to port 5.
