Changing password hotspot for 100 + user via script
Hi, i have this problem.
In which i have to change the password for more than 100 user in the user-manager user.
Let’s say here’s the list of my user
user101
user102
user103
user105
user107
user357
in which among the list there was some number that wasn’t there, like user 113, 115, 213.
Until this day, i change the password manually, but since i’ve want to make use the script function so it change by itself on weekly basis as the script running.
But i’ve met a trouble since i cann’t found the “*” or “%” (prefix) to make the script do checking the user first, if the user was there so the system change the password.
here’s the code that i’ve try to check the user first, i haven’t make the script to change the password.
#script change passwd user hotspot
:local Flag
:set Flag [/tool user-manager user find name="user???"] [color=#FF0000]<<<< i want to change ??? to symbol like % or * so it's automatically detect all the user[/color]
:if ([:len $Flag] > 0) do={/tool user-manager user append file uwifilog;}
for the above code, i make file uwifilog as the output for the user that was found by the script.
or should i change the script into this
#script remove log userman
    :foreach i in=[/tool user-manager user find name="user???"] do
as for the password, i usually change the “keyword” that followed by number like on the user
say for the
name = “user101”
password = “keyword101”
name = “user102”
password = “keyword102”
no change for the number, for user351, the password is keyword351.
Only keyword changed, like volcano, so the password is volcano351 for user351
and so on for the other user.
i want to make the script look like this:
:foreach i in=
:local currentPassword [/tool user-manager user get [/tool user-manager user find name="user.$i"] password];
:local number [:tonum [:pick $currentPassword 8 10]];
:set newPassword ("sea" . $number);
do
/tool user-manager set [/tool user-manager user find name="user.$i"] password = "$newpassword";
:until $i = 400
:break
could anyone help me on this problem
NB:
to change value that draw from the system like
into number we use :tonum to change the value into numeric
what about changing the value into string, would it be like
#:local keyword [:tostr [:pick $currentPassword 1 7]]; <<< is this right?
:local prefix "volcano";
:foreach USER in=[/tool user-manager user find name~"^user"] do={
  :local number  [:pick $user 4 [:len $user]];
  :local newPassword ($prefix . $number);
  /tool user-manager set $USER password=$newPassword;
Fewi thanks for the reply,
i’ve made change to the script so it run.
the script on my side is like this
:local prefix "keris";
  :local number  [:pick $USER 5 7];
  :local newPass ($prefix . $number);
  /tool user-manager user set $USER password=$newPass;
