Changing port vlan config
Hello.
I have found information on initial configurations using command line but not much on making changes on switches.
I need to change the configuration of an sfp port on a CRS326-24G-2S+ and would like to do this via the command line.
It is currently set up as a trunk port in a multiple VLAN configuration. I now need it as an access port for a single VLAN, since it is now connected to a server with a new 10G network card.
I can’t work out the syntax to do this. Do I need to completely remove it from the bridge and start from scratch or can I use the “set” command to reconfigure it?
Below is the current VLAN config. I need to repurpose “sfp1” as an access port on VLAN 1015 and leave “sfp2” as the trunk port.
interface bridge vlan print detail
Flags: X - disabled, D - dynamic
0 bridge=BR1 vlan-ids=22 tagged=sfp1,sfp2 untagged=ether2 current-tagged=sfp2 current-untagged=“”
1 bridge=BR1 vlan-ids=1005 tagged=sfp1,sfp2 untagged=ether3,ether4,ether5,ether6,ether7,ether8 current-tagged=sfp2
current-untagged=ether3,ether4
2 bridge=BR1 vlan-ids=1030 tagged=sfp1,sfp2 untagged=ether9,ether10,ether11,ether12 current-tagged=sfp2
current-untagged=ether10,ether12
3 bridge=BR1 vlan-ids=1006 tagged=sfp1,sfp2 untagged=ether13,ether14,ether15,ether16,ether17,ether18 current-tagged=sfp2
current-untagged=ether14,ether18,ether13,ether16
4 bridge=BR1 vlan-ids=1015 tagged=BR1,sfp1,sfp2 untagged=ether19,ether20,ether21,ether22 current-tagged=BR1,sfp2,sfp1
current-untagged=“”
5 D bridge=BR1 vlan-ids=1 tagged=“” untagged=“” current-tagged=“” current-untagged=BR1
I have tried to work out the syntax but cannot get it to work.
Thanks.
You don’t need to remove it from the bridge, it can be set and changed. However, if spanning tree is running on the bridge and this is a prod network, be mindful of changes that can cause the STP topology to reconverge.
Thanks for the reply. Yes it is a production environment. Good to know about RSTP.
I was looking for clues as to the exact syntax because when I try “/interface bridge vlan set vlan-ids=1015 [find interface=sfp1]” as a starting point I get no joy. As you can see from the printout it is currently set up as a trunk port with ingress filtering for tagged only and a member of all vlans. I need to change it to an untagged member of 1015 only.
Can anyone help with the exact syntax?
Do I need to re-write the whole VLAN table like this (removing sfp1 as tagged on all VLANS and making it an untagged member of 1005):
set bridge=BR1 tagged=sfp2 untagged=ether2 vlan-ids=22
ether3,ether4,ether5,ether6,ether7,ether8,sfp1 vlan-ids=1005
ether9,ether10,ether11,ether12 vlan-ids=1030
ether13,ether14,ether15,ether16,ether17,ether18 vlan-ids=1006
set bridge=BR1 tagged=BR1,sfp2 untagged=
ether19,ether20,ether21,ether22 vlan-ids=1015”
And then set sfp1 port as an access port:
“/interface bridge port
set bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged
ingress-filtering=yes interface=sfp1 pvid=1005”
Any help would be appreciated.
Can anyone help with this?
Hay i think you need to run ether channel and rstp first.
and there is my vlan config currently running in site.
Port base vlan in bridge.
add name=Bridge vlan-filtering=yes
set [ find default-name=ether24 ] mac-address=CC:2D:E0:8F:EF:AC
/interface bonding
add mode=802.3ad name=“EtherChannel Trunk” slaves=ether23,ether24
transmit-hash-policy=layer-2-and-3
add bridge=Bridge interface=ether2 pvid=10
add bridge=Bridge interface=“EtherChannel Trunk”
add bridge=Bridge interface=all
add bridge=Bridge tagged=“EtherChannel Trunk” untagged=
ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=10
ether9,ether10,ether11,ether12 vlan-ids=20
ether13,ether14,ether15,ether16 vlan-ids=30
ether17,ether18,ether19,ether20 vlan-ids=40
add bridge=Bridge tagged=“EtherChannel Trunk” untagged=ether21,ether22
vlan-ids=50
