Hi everybody
How can i change or update any dynamic queue for example changing the max-limit for it ?
i tried to do that by terminal and i got :
queue simple set max-limit=“5” numbers=15
failure: cannot change dynamic
Hi Sinan.
It is not possible to edit a dynamic queue entry.
Maybe you could try edit where it is called like hotspot or PPP profile and then reload the user to take change.
Thanks for your reply but it is bad to make user sign in many times since i want the rate to change many times a day
Why you don’t try use manual entry instead dynamic? . Maybe you will have more advantages than disadvantages.
Bcz of using hotspot with dchp so the user will have a different IP each time and i dont wanna use static IP
Any Solution. I need for PPPOE user with user Manager.
If you change user-manager profile, pppoe queue change accordingly without logoff the user.
