Ww cannot unlock frequencies over 2499mhz. The configuration is :
Routerboard 133c
Mikrotik OS 2.9.42 Level5, extra channels license
Mpci R52-350
No country select
Superchannel
I see only 2312 until 2499 frequencies
Anyone knows what is wrong ?
Routerboard 133c
Mpci R52-350
No country select
Superchannel
Anyone ready to help or just to view?
post your wireless settings
this is out of 802.11 standard, the wireless cards don’t support these frequencies themselves. Most cards support only 2.312 - 2.497 or 4.920 - 6.100GHz range
Normis the Card is Mikrotik R52-350 which means and I think it is R52H and this card should work over 2.5Ghz. This is the strange thing cus Iv tried everything on settings changing cards but again I see only -2499 in the end.
from this link:
http://www.mikrotik.com/pdf/R52H.pdf?md5=1202132757
as you see, you have to use the 5Mhz step option, and of course the latest RouterOS v3.2
Thank you Normis, I tried 5Mhz step but It seems that I have to update OS allso becouse it doesnt work on version 2.9.42
yes, it works only in v3
Does R52 has this feature allso or only R52H
no, R52 doesn’t go so far:
http://www.mikrotik.com/pdf/R52.pdf?md5=1202454724
