CHART not working
I am configuring data sources based on OID about HD in Windows 2003.
With WS Ping Pro Pack SNMP navigator, I can see OID value. I set up this value in Data Source (Gauge) not rate. But the chart is not working.
It do not draw the reference lines as it do when I use a Builtin variable and of course do not draw the graph line.
Is someone having the same problem? am I misconfiguring something?
Greeted in advance
Antonio Sanchez
I have the same problem :frowning:
I hope they make it so you can chart any SNMP mib but so far none work other than the build in services.
The Only way I got SNMP OIDs to work as to do a SNMPwalk on the device using the tools menu. Once I found the OID I needed did a right click and selected add as Data Source.
If done this way the data is collected and then can be placed in a chart
I am having this same problem. Even when I find the oid with snmpwalk and create a data source. When I test the oid it returns a value of 0 even when the snmpwalk shows a real value of 30 (rssi). Is this a config problem? I am trying to graph RSSI from a deliberant 2300. this is the oid: 1.3.6.1.4.1.99.5.101.1
same problem, even right clicking on the specific oid showed from an snmpwalk…
Any has it working?
