Charting bandwidth
We are looking to create a chart of the bandwidth of an airfiber. We have written the code as follows.
rate(oid(“1.3.6.1.4.1.41112.1.3.3.1.6.1”))
With this code, we are consistently getting the same value, almost as if it is relaying back the counter value instead of the rate of the counter. The value it is returning appears to be the maximum possible value because it grows to a certain point then stops changing. Is there a better way to write this code so that it gives us the mbps?
Try this
round(rate(diff32(oid(“1.3.6.1.4.1.41112.1.3.3.1.6.1”))*8))
Thanks. That works great.
