Hello
I need help please.
I’m in south Portugal,
Connected my MEO sim card,
I can see in the interface that it is recognized and everything seems ok but there is no internet access.
Please help me resolve this
Hello
I need help please.
Very often the issue is with the APN.
Make sure what the MEO APN should be, “internet” is probably a generic one.
In some cases you need to explicitly set:
use-network-apn=no
https://help.mikrotik.com/docs/display/RKB/Chateau+LTE12+APN+problem
http://forum.mikrotik.com/t/lte-apn-with-fix-ip/139907/1
if you manually put “internet” as the APN it won’t be considered unless the use-network-apn is set to “no” (the Mikrotik default is “yes” for this setting)
See also:
http://forum.mikrotik.com/t/asking-for-help-with-lte-connection/176786/1
and update your modem firmware - see red message top right.
