Chateau 5G ax R17 Private 5G support
Few private 5G questions regarding the Chateau 5G ax R17
(1) Has anyone tested Private 5G Band n77? Specs says it supports 5G n77 SA but does it support a PLMN of 999 XX! - Not all do
(2) If you have tested private 5G was it with esim or physical sim or even better both!
(3) Does it support 5G dual layer uplink?
Thanks in advance
