Chateau 5G - not working after update
Chateau 5G - after update LTE / 5G is not working.
I was reading on this forum that version 7.0.3 is Chateau 5G only.
Can someone upload 7.0.3 for Chateau 5G because all old links are dead.
Thx in advance
What version did you update to? 7.1rc2 should work fine on it
Yes i am using te latest one. 7.1rc2
maybe modem needs new firmware but it says that ip is unrechable.
Noone simply updates to 7.1rc2 without config reset.
you were right. it works with 7.1rc2
sorry about that. I had bad expirience with SXT LTE 6.
Out of the box it didnt work until modem upgrade and it had to be done over LAN.
best regards
