Hi Everyone
I would be very grateful for some help with this.
I have set up a port forwarding rule but it is not working.
The rule is for a VNC server on my laptop. It is as follows:
Chain: dstnat
Protocol: tcp
Dst. Port: 5900
Action: dst-nat
To-Addresses: 192.168.88.254
To-Ports: 5900
The IP address mentioned above is the IP address of my laptop.
The input for the rule is via an L2TP service from Andrews & Arnold which I have configured on the Chateau 5G.
When, I try to log on to the VNC server from another computer on the Internet, there is no response at the other computer’s end. However, the log-on attempt creates a spike in the rate graph towards the bottom of the configuration page for the port forwarding rule. There is however no corresponding spike in the packet rate graph below the rate graph. I am guessing that this means that the rule is being successfully triggered but the action is failing.
Does anyone know why the action is failing?
Please note that I can succesfully log on to the VNC server of the laptop from another computer on the same LAN as the laptop so the problem is not on the laptop.
My configuration is as follows: (I have used asterisks to redact any sensitive information)
# sep/27/2022 15:20:18 by RouterOS 7.2.3
# software id = FZCI-6TGI
# model = D53G-5HacD2HnD
# serial number = *****
add admin-mac=***** auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] allow-roaming=no band=1 name=lte1 network-mode=lte,5g nr-band=78
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
MikroTik-***** wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor \
mode=ap-bridge ssid=MikroTik-***** wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication=chap name=Vodafone use-network-apn=no \
user=web
add apn=mob.asm.net default-route-distance=100 name=Three use-network-apn=yes
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/interface l2tp-client
add allow=pap,chap,mschap2 connect-to=***** disabled=no \
keepalive-timeout=disabled name="A&A L2TP" profile=default user=*****
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
192.168.88.0
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=VNC dst-port=5900 protocol=tcp \
to-addresses=192.168.88.254 to-ports=5900
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set port=lte1 receive-enabled=yes
