I am having an LTE attach problem on a MikroTik Chateau device with Quectel RG650E-EU modem.
The modem can detect and monitor LTE cells normally, signal quality is good, but it never attaches to the network.
Tested RouterOS versions:
7.19.6
7.22.3
7.23rc
Same issue on both versions.
I also changed LTE mode from QMI to MBIM, but there was no difference.
Current symptoms:
AT+CGREG?returns0,0 -
AT+CREG?returns2,0 -
AT+CGATT?returns0 -
AT+CEERreturnsNo cause information available -
Manual attach also fails
The modem sees nearby LTE cells correctly:
/interface lte at-chat lte1 input="AT+QENG=\"servingcell\""
Example:
+QENG: "servingcell","LIMSRV","LTE","FDD",432,11,166E13F,101,1329,3,4,4,A0FD,-93,-13,-60,13,0,-,30
Neighbour cells are also visible normally.
APN configuration:
IPV4V6
APN: ipstaticb2c.mci
I also checked:
SIM is detected (
CPIN: READY) -
Signal is stable
LTE bands are visible
Reboot and modem reset performed
AT+CFUN=1,1tested -
usbnetmode changed/tested -
MBIM and QMI both tested
Has anyone seen a similar issue with RG650E-EU or attach failures on recent RouterOS versions?
Any suggestions for deeper MME reject debugging or modem firmware recovery would be appreciated.
[admin@Chateau] > /interface lte at-chat lte1 input="AT+QENG="servingcell""
output: +QENG: "servingcell","LIMSRV","LTE","FDD",432,11,166E13F,101,1329,3,4,4,A0FD,-93,-13,-60,13,0,-,30
OK
[admin@Chateau] > /interface lte at-chat lte1 input="AT+QENG="neighbourcell""
output: +QENG: "neighbourcell intra","LTE",1329,101,-11,-92,-62,-,31,255,40,0,52
+QENG: "neighbourcell intra","LTE",1329,94,-17,-100,-70,-,23,255,40,0,52
+QENG: "neighbourcell intra","LTE",1329,264,-12,-99,-77,-,24,255,40,0,52
+QENG: "neighbourcell intra","LTE",1329,218,-18,-101,-74,-,22,255,40,0,52
+QENG: "neighbourcell intra","LTE",1329,216,-20,-106,-74,-,17,255,40,0,52
+QENG: "neighbourcell intra","LTE",1329,265,-18,-105,-77,-,18,255,40,0,52
+QENG: "neighbourcell inter","LTE",39550,-,-,-,-,-,31,6,10,10
+QENG: "neighbourcell inter","LTE",3300,101,-8,-93,-77,-,23,255,10,10
+QENG: "neighbourcell inter","LTE",3300,264,-17,-102,-77,-,23,255,10,10
+QENG: "neighbourcell inter","LTE",3300,63,-16,-103,-77,-,23,255,10,10
+QENG: "neighbourcell inter","LTE",1500,101,-9,-97,-79,-,24,255,10,10
+QENG: "neighbourcell inter","LTE",1500,264,-15,-100,-77,-,24,255,10,10
+QENG: "neighbourcell inter","LTE",1500,99,-20,-107,-79,-,24,255,10,10
+QENG: "neighbourcell inter","LTE",1500,94,-16,-103,-79,-,24,255,10,10
+QENG: "neighbourcell inter","LTE",1500,400,-14,-102,-79,-,24,255,10,10
+QENG: "neighbourcell inter","LTE",425,101,-10,-92,-73,-,22,255,10,10
+QENG: "neighbourcell inter","LTE",425,218,-20,-101,-68,-,22,255,10,10
+QENG: "neighbourcell inter","LTE",425,63,-20,-102,-73,-,22,255,10,10
+QENG: "neighbourcell inter","LTE",425,488,-20,-94,-64,-,22,255,10,10
+QENG: "neighbourcell inter","LTE",425,264,-20,-112,-80,-,22,255,10,10
+QENG: "neighbourcell inter","LTE",425,36,-20,-94,-63,-,22,255,10,10
+QENG: "neighbourcell inter","LTE",3102,101,-12,-98,-77,-,17,255,10,10
+QENG: "neighbourcell inter","LTE",3102,63,-17,-103,-77,-,17,255,10,10
+QENG: "neighbourcell inter","LTE",3102,264,-17,-105,-80,-,17,255,10,10
+QENG: "neighbourcell inter","LTE",38950,63,-14,-108,-86,-,18,255,10,10
+QENG: "neighbourcell inter","LTE",38950,95,-18,-112,-86,-,18,255,10,10
+QENG: "neighbourcell inter","LTE",38752,63,-14,-110,-85,-,0,255,10,10
+QENG: "neighbourcell inter","LTE",38752,95,-13,-109,-85,-,0,255,10,10
OK
[admin@Chateau] > /interface lte at-chat lte1 input="AT+CGREG?"
output: +CGREG: 0,0
OK
[admin@Chateau] > /interface lte at-chat lte1 input="AT+CREG?"
output: +CREG: 2,0
OK
[admin@Chateau] > /interface lte at-chat lte1 input="AT+CGATT?"
output: +CGATT: 0
OK
[admin@Chateau] > /interface lte at-chat lte1 input="AT+CGDCONT?"
output: +CGDCONT: 1,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,,"",,,,0
+CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,,"",,,,0
+CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1,,,,,,,,,,"",,,,0
+CGDCONT: 4,"IPV4V6","ipstaticb2c.mci","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,,"",,,,0
+CGDCONT: 5,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,,"",,,,0
OK
[admin@Chateau] > /interface lte at-chat lte1 input="AT+QCFG=?"
output: +QCFG: "rrc",(0-5)
+QCFG: "hsdpacat",(6,8,10-24)
+QCFG: "hsupacat",(5,6)
+QCFG: "pdp/duplicatechk",(0,1)
+QCFG: "risignaltype",("respective","physical")
+QCFG: "lte/bandprior",(1-43),(1-43),(1-43)
+QCFG: "volte_disable",(0,1)
+QCFG: "diversity/config",(0,1),(1-8),(0)
+QCFG: "div_test_mode",(0,1)
+QCFG: "usbnet",<0-3>
+QCFG: "usbspeed",("20","311","312")
+QCFG: "data_interface",(0,1),(0,1)
+QCFG: "pcie/mode",(0,1)
+QCFG: "sms_control",(0,1),(0,1)
+QCFG: "call_control",(0,1),(0,1)
+QCFG: "netmaskset",(0,1)[,]
+QCFG: "clat",(0,1),(0,1),,(0,32,40,48,56,64,96),,(0,1),(0,1,2,4,8),(0,1),(0,1),(0,1,
2),(0,1,2)
+QCFG: "enable_gea1"[,(0,1)]
+QCFG: "dhcppktfltr",(0,1)
OK
