Try set modem-init=“ATI” to check if works. What you insert to that command ? I never used it for not MikroTik LTE Modules and maybe they not work… check logs to be sure if it’s put at proper time of modem inistialization.
Hi I have tried to configure this with Chateau LTE12 but failed. Is there any support for Passthrough to this Router .
If it is not fixed when will it be a fix for it to work.
//Peter
Grz333 say:
Ask at directly at support@mikrotik.com .
