Chateau LTE18 AX or Chateau 5G AX
Need a little bit of advice. I am planning to buy Chateau model, but have not decided which one to get. I am torn between LTE18 AX or 5G AX.
I have 400m to closest tower, which supports LTE 800, 1800, 2100 and 2600 with my mobile provider. Same tower has got also 5G on N1 for the same provider.
At the moment I have HUAWEI B535 router and I am getting around 70MB/s download. When I use my IPhone with 5G, I am getting around 170MB/s from the same tower.
My router is only LTE 6, so Chateau LTE18 AX should improve download speeds and I can get one now. When it comes to Chateau 5G AX, they are out of stock everywhere.
Also, 5G model is 2x more expensive to get, but I have no problem with that. I am just wondering if it worth getting 5G model with my tower situation now, or maybe wait for a possible future WiFi 6E model and just get LTE 18 AX. Any advice would be appreciated.
