Has anybody tried the chateau pro ax? How is WiFi performance and range? I have the ax3 and WiFi seems very poor and drops frequently.
The what, I cannot find any such model.
I see the Chateau 5G AX??
There will be no appreciable difference.
Suggest considering TPlink and Zyxel wifi 7 products.
OR
add another MT product in the home for better coverage capax for example.
I think anav has lost the Google magic with his change to tp-link ![]()
But on the PRO ax:
It has a different 5Ghz chipset. Most complaints about the 5ghz Wi-Fi is usually just about AX2/AX3 and cap AX which all have the same chipset.
WAP AX has a different chipset too, for example.
But in the end if its just about range (and disconnects on “far” clients) maybe a channel switch might help
