[ChateauLTE12] wifi working but not LAN
I’m new here and I’m not really very technical about network problems.
I had just bought a CHateau LTE12 router. My Sim card is working because I could connect to the internet through the Chateau LTE12 wifi.
Nevertheless, if I connect my computer to the router with a ethernet cable, it does not work.
It looks like eth1 is working because I see some packages but it’s not connected to the LTE.
bellow, the /export :
[admin@MikroTik] > /export
# may/07/2024 06:41:18 by RouterOS 7.2
# software id = 6F88-075P
# model = D53G-5HacD2HnD
# serial number = HD2083WSJB9
add admin-mac=18:FD:74:8F:29:75 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="french polynesia" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-8F297A \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="french polynesia" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-8F297B wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=mmsbouygtel.com use-network-apn=yes
add apn=ebouygtel.com ip-type=ipv4 use-network-apn=yes
add apn="Orange Internet" use-network-apn=yes
add apn=IM use-network-apn=yes
/interface lte
set [ find ] allow-roaming=yes apn-profiles=IM band="" name=lte1
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
/interface lte settings
set external-antenna=auto
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Someone can help please ? :slight_smile:
thx
Your config looks okay (at first sight), masquerade is configured.
Can you tell exactly what is not working?
Did your DHCP client receive an IP address?
Can you ping (i.e. 9.9.9.9) from the router?
You might want to consider upgrading RouterOS and firmware, as it is a bit old.
That is a good testcase to see if LTE is working correctly.
Nothing (obviously) wrong with the configuration. Faulty Ethernet cable or misconfigured client device. check your IP settings on your client.
Indeed, my computer was not in DHCP mode … !
Now it works
Thx
