Cheateau LTE12 no no internet using LTE with specific ISP, 3G works fine
First of all I’d like to say that I’m very new to networking in general but I know quite a bit about mobile networks so forgive me if I don’t understand things straight away :slight_smile:
Basically what I’m trying to do is quite simple, I just want to get an internet connection over LTE.
My problems are currently that I can get the router to connect to LTE just fine, even using carrier aggregation but I can’t access the internet. This problem only occurs on Telekom Germany’s LTE network, their 3G works fine and other LTE networks work fine as well. I of course configured the APN and tested other devices as well. With my phone I can get 60-90 Mbit/s here so the problem has to be something with my config.
System \ Logging \ add new topic=lte
Then try connect to lte.
Do reboot for clear logs, lte should try connect… and then do
/log print file=log.txt
Give us that file as attachment or some pastbin.
You must know that APN in logs can show you that he is not used, and grab from ISP… then you must use from terminal
[admin@MikroTik] > interface/lte apn/set use-network-apn=
no yes
