Check a file date
I’m a user of The Dude v4.0 beta 3 and I want to know if it’s possible to check the date property of a file?
It’s a backup file log (toto.txt) which change every day and I have to check the last date modification to verifiy if the backup works correctly or not.
Thanks for answers.
Best regards
Use a scheduled task… Write a batch job that can determine if the date is too old and if it is return 0 otherwise return 1, the dude can run it as an external. Search for execute in this forum.
Lebowski
Ok I will try this.
