Check my config please
Just got a new Hex to replace a Verizon G3100 (while waiting for an RB5009).
Could someone please check my config to see if I’m secure? I forward ports 5800 and 5900 for VNC, and 8123 for Home Assistant.
Thank you!
# oct/18/2022 05:47:15 by RouterOS 6.49.7
# software id = C3RH-692B
# model = RB750Gr3
# serial number =
add admin-mac=18:FD:00:00:00:00 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.2.100-192.168.2.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.2.2/24 comment=defconf interface=bridge network=\
    192.168.2.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.2 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.2.2 comment=defconf name=router.lan
add action=accept chain=forward dst-port=5800 in-interface=ether1 log=yes \
    protocol=tcp
add action=accept chain=forward dst-port=5900 in-interface=ether1 log=yes \
    protocol=tcp
add action=accept chain=forward dst-port=8123 in-interface=ether1 log=yes \
    protocol=tcp
    established,related,untracked
add action=drop chain=input in-interface=ether1 log=yes
add action=accept chain=forward in-interface=ether1 out-interface=bridge
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    ipsec-policy=out,none out-interface-list=WAN src-address=192.168.0.0/16
add action=src-nat chain=srcnat dst-address=192.168.2.22 dst-port=5800 log=\
    yes protocol=tcp to-addresses=192.168.2.22
add action=src-nat chain=srcnat dst-address=192.168.2.22 dst-port=5900 log=\
add action=src-nat chain=srcnat dst-address=192.168.2.176 dst-port=8123 log=\
    yes protocol=tcp to-addresses=192.168.2.176
add disabled=yes distance=1 gateway=192.168.2.1
/system clock
set time-zone-name=America/New_York
/system identity
set name=RouterOS
/system ntp client
set enabled=yes primary-ntp=216.239.35.4 secondary-ntp=104.16.132.229
/tool mac-server
/tool mac-server mac-winbox
/tool traffic-monitor
add interface=ether1 name=tmon1
It would appear you no clue on how to use firewall rules.
Start with the defaults… and then add DST nat rules for the specific ports.
Only one rule required in forward chain for port forwarding in general.
Suggest some reading…
https://forum.mikrotik.com/viewtopic.php?t=179343
also firewall basic something like this will work for you…
THen simply add any additional rules required in the forward chain which will be few to none…
Order of rules is important…
{Input Chain}
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else" *****
{forward chain}
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
Thank you so much for your help!
I did not want to leave the VPN active, but unchecking it leaves all the VPN-related entries in the exported config file. I don’t know how to remove them permanently.
Is this better:
# oct/18/2022 10:00:15 by RouterOS 6.49.7
# model = RB750Gr3
# serial number = Hxxxxxxx
add admin-mac=18:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
add name=vpn ranges=192.168.89.2-192.168.89.255
/ppp profile
set *FFFFFFFE bridge-learning=no local-address=192.168.89.1 remote-address=\
    vpn
/interface l2tp-server server
set use-ipsec=yes
/interface sstp-server server
set default-profile=default-encryption
    192.168.2.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
/ip dns static
    "NEW defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="NEW defconf: drop invalid" \
add action=accept chain=input comment="NEW defconf: accept ICMP" protocol=\
    icmp
add action=accept chain=input comment=NEW in-interface-list=LAN
add action=drop chain=input comment="NEW drop all else" log=yes
add action=fasttrack-connection chain=forward comment=\
    "NEW defconf: fasttrack" connection-state=established,related
    "NEW defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="NEW defconf: drop invalid" \
add action=accept chain=forward comment="NEW allow internet traffic" \
add action=accept chain=forward comment="NEW allow port forwarding" \
    protocol=tcp
    protocol=tcp
    protocol=tcp
add action=drop chain=forward comment=NEW
add action=masquerade chain=srcnat comment="NEW defconf: masquerade" \
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
/ppp secret
add name=vpn
/system clock
/system identity
set name=RouterOS
/system ntp client
/tool mac-server
There was no VPN config in your first post??
Okay I see them in your second,
Why all the VPN, did you consider using just wireguard for example?
What are the requirements???
(1) You have the required handshake INPUT CHAIN RULES, to access the router VPN services.
One does not put the same rules in the forward chain ??? Should be removed!!
protocol=tcp
protocol=tcp
protocol=tcp
(2) You have a duplicate forward chain LAN TO WAN RULE but LOL< you stuck in the DST NAT rules… Remove part in orange.
Then you have the wrong format for you port forwarding rules.
On what planet is an external user pointing at your local LAN server IP ???
An external user points at your WANIP, and then via Router rules you move that traffic with the correct destination port to the local LAN server IP.
The correct entry depends on what type of WANIP connection you have. ( Dynamic WANIP, or fixed STATIC WANIP
dynamic use: in-interface-list=WAN
Static use: dst-address=static WANIP
add action=masquerade chain=srcnat comment=“NEW defconf: masquerade”
add action=accept chain=forward comment=“NEW allow internet traffic”
(3) plain mac-server only is not encrypted/secure thus change it to NONE.
/tool mac-server
In QUICK SET, I checked the VPN checkbox. Then I unchecked it. But the entries remain when I export the config.
I removed the port forwarding from the INPUT CHAIN RULES – thank you.
When I removed this line I lose outbound (LAN to WAN) connectivity:
add action=accept chain=forward comment=“NEW allow internet traffic” in-interface-list=LAN out-interface-list=WAN
I was going to tackle Wireguard next. You previously helped me setting up Wireguard with another Hex so I hope I can get it working on this one without further help.
(1) You removed the wrong internet traffic rule… I said duplicate and told you which copy to delete even…
to reiterate…
NOT THIS ONE (in correct spot in forward chain)
add action=accept chain=forward comment=“NEW allow port forwarding”
THIS ONE: ( in nat rules wrong!!)
(2) You just need to go into the PPP menus do remove all those settings…
YOu can go into the input chain on /ip firewall filter and remove all the added rule s there;
IPSEC nat
IKE
l2TP
pptp
sstp
Thank you again very much.
I posted another question about VLAN config on a CSS326 in SWoS. Should I post it here instead?
No that is a separate enough topic and you should keep it there…
If you are using any etherport on the MT device here though, to connect to that switch, that would be good to know, as it will be a trunk port…
Yes, the CSS326 is connected to the Hex port #2 (ether2).
No vlans coming from the h ex though.
I’m still having problems.
I have Home Assistant on private IP 192.168.2.176 port 8123
From outside my LAN I can access it fine.
From inside the LAN, if I point a browser to 192.168.2.176:8123 it works.
But, if from inside the LAN I point to the :8123 it fails.
Do I need some sort of rule to allow this?
Here’s what I’ve got in the firewall.
Thank you!
add action=accept chain=input comment="NEW defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="NEW defconf: drop invalid" connection-state=invalid
add action=accept chain=input comment="NEW defconf: accept ICMP" protocol=icmp
add action=fasttrack-connection chain=forward comment="NEW defconf: fasttrack" connection-state=established,related
add action=accept chain=forward comment="NEW defconf: accept established,related, untracked" connection-state=established,related,untracked
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="NEW allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="NEW defconf: drop invalid" connection-state=invalid
add action=masquerade chain=srcnat comment="NEW defconf: masquerade" out-interface-list=WAN
add action=src-nat chain=srcnat comment="new 8123" disabled=yes dst-address=192.168.2.176 dst-port=8123 protocol=tcp to-addresses=192.168.2.176
add action=src-nat chain=srcnat comment="new 5800" disabled=yes dst-port=5800 protocol=tcp to-addresses=192.168.2.22
add action=src-nat chain=srcnat comment="new 5900" disabled=yes dst-port=5900 protocol=tcp to-addresses=192.168.2.22
add action=dst-nat chain=dstnat dst-port=8123 log=yes protocol=tcp to-addresses=192.168.2.176
Whew – solve it!
You had mention previously about Hairpin Nat and that is what solved my problem.
I used this thread:
http://forum.mikrotik.com/t/hairpin-nat-the-easy-way/146718/1
Excellent, yes the article on port forwarding I linked at the top of the thread, explains hairpin nat in detail.
